1 - 20 of 20 Posts
Looking to do some mods and want to make sure the order I am going to do them in is correct. I have an 07' 6.7 w/130,000 miles on it. It is a 4x4 DRW 4 door. I already did the AFE Filter & Exhaust. This is the order I want to do my upgrades in.
1. DPF Delete
2. EGR Delete
3. FASS System
4. TS- MP8
5. Edge w/Attitude
I want to make sure I delete this emission crap before I start dumping more power & I want to make sure I can pump enough fuel once I add on the power. Does this route seem the best way to go. I use this truck everyday to haul across the US & Canada. I haven't had ANY problems with it and I want to keep it that way. Any input on this would be great.
Thanks
Thats an impressive amount of miles for a fairly new engine. Do you still have the same turbo and injectors?
Same Turbo & Injectors as the day I bought it. Haven't had any check engines lights come on, regen issues, not a damn thing go wrong. Now my 07" 5.9 is a different story. I smoked that tranny @ 40k so I bought this one for work and now got 2 truck payments with my 5.9 modified to the max and the wife drives it and I'm stuck with the stock 6.7. I am out of a warranty now and time to see better MPG and Horsepower out of her. I can only imagine the soot build up I got after 130K when people talk about it when they only have 5k on the truck. Scray if you ask me.
Also once those mods are done should I do water/methanol injection? I got my shopping cart fuel on Kevins website and just waiting to check out but wondering about water/methanol.. Is it good for what I do as far as the miles & loads I haul?
Thanks
Jeremiah
i was wanting to get a fass and a pmt... but was wondering if i should get the fass first before them pmt? if i did would there be any issues of like too much fuel or anything?
o yea water meth is defentatley good for gas mileage, hauling and power
How long does the water/methanol last before you have to refill it. I have never seen the system and don't really know much about it. I do about 6,000k miles a week on my truck.
Holy crap
when do you have time to sleep?
Driving 7 days a week for 12 hours a day at an average speed of 70mph will almost put 6,000 miles per week on a rig. Are you the only driver?
Your order seems to be a good plan. You could do the edge before the FASS and before the current EGR delete as you will want to get rid of the codes. Water/Meth would be last. Also If you have a manual you will need to upgrade the clutch and an auto will need some help too, IMO.
1. DPF Delete
2. EGR Delete
3. FASS System
4. TS- MP8
5. Edge w/Attitude
Thanks
Well in less you want to wait for the code free exhaust delete, you will have to get the edge w/Att to delete the soft codes that it will throw.
Also, if you want the egr delete again you will have to have the Edge w/Att to delete the soft code.
Other wise you wont know when something else goes wrong, because the check engine light will be already on.
Just my 2 cents.:thumbsup
I would do in this order:
1 exhaust and Edge w/ att
2 air intake
3 egr delete
4 mp-8
5 intercooler
6 fass or dog with injectors
Dumb question I know, but what upgrades do you do to the intercooler?:thud:
You get a new from Banks or another high performance manufacturer. They don't lose any pressure, or leak, and I don't remember the numbers for sure but they cool the air charge alot more than the stocker. They will also flow more air.
I still can't get over the 6,000mi/week thing.
Discussion Starter #14
Yes. But when I am empty (not hauling for hire) I will run about 16-18 hours in a day which will give me about 1000-1100 miles. I live in Phoenix and mostly deliver to Canada so the miles can be racked up quickly
Discussion Starter #15
Hell that ain't nothin. You should see my fuel bill. It's impressive but not something that is a positive to talk about. My rig hold 135 gallons (100 gal transfer flow tank). Hauling heavy I get about 9-10 so a weekly fuel bill cal be $2600 +/-
Have you ever thought about replacing your stock fuel tank with a 50 or 60 gal tank over your 35gal tank to get more range?
Wont help with fuel bill but you can go a little longer between fill ups.
What do those typically go for?:$:
Discussion Starter #18
When I did my first truck with the Transfer Flow tank I looked into that but it was almost the same price as putting there 100 aux tank in. Also If I carry 150 gallons of fuel just adds more weight to my truck and @ 10mpg I wouldn't be able to drive 1500 miles in 1 day. I stop @ the truck stops each night and refuel/shower up so having to much fuel is just a waste of weight.
I can do about 1900 miles on 135 gallons if I am empty and cruising 70mpg down the freeway. You mpg kill you the more weight you add onto your rig so I try to fill just enough full for my driving needs that day and a little extra for traffic delays, etc.
dosent the stock 6.7 have a big enough intercooler? heard that they were pretty large and you dont need to mod them unless u get into some big numbers
just my two cents on the water/meth that my brother put on his 6.7 it was a joke and drinks the "boost juice" like its goin outta style he also has an edge/att. and my 6.7 with a bully dog and mp8 smoked him bad
1 - 20 of 20 Posts
