aFe POWER is happy to be apart of the Cummings Forum community, and discuss Cummings performance with all of you. We would like to start off by introducing the Momentum HD Pro-Guard 7 Stage-2 Intake System, for RAM Diesel trucks from 2013-2015 with the L6-6.7L Cummins Turbo Diesel Engine. This intake system out flowed the factory intake system by 58%, which is confirmed by our in house flow bench. Our intake system increased horsepower by +7 and increased torque by a respectable +18.
Our one-piece sealed housing retains the RAM Active Air Technology, which acts as a dual air inlet airbox that monitors the amount of air and where it is coming in depending on under hood temperatures and outside conditions. A large clear sight window helps you inspect your air filter easily without having to remove the box while adding an aggressive style.
The Momentum HD was designed around a huge Pro-Guard 7 performance 360 degree radial flow air filter. The filter has 5 layers of progressive cotton media that adds an additional 2 layers of progressive synthetic media, which equals to a 99.7% cumulative efficiency for maximum filtration capability. The unique air filter to housing interface allows the biggest filter size to be used, while also increasing the available air volume and adding simplicity to the install. To prevent filter collapse, the filter is wrapped with a reinforced metal which adds increased strength. This kit is also available with an oil free Pro Dry S filter option.
Premium Hardware was chosen which includes premium stainless steel T-bolt clamps, and a 3-Ply reinforced silicone coupler for a superior seal and strength while providing the most secure install possible. Momentum HD intake kits are designed with fewer parts for a quicker and simpler install without the hassle.
Product detail link: Cold Air Intake System Momentum HD Momentum HD Pro-GUARD 7 Stage-2 Intake System;ÂRAM Diesel Trucks 13-15 L6-6.7L (td) 75-72005 - aFe Power
Quick Data Points:
• +7hp and +18 lbs. x ft. of torque increase over stock
• Outflows the factory intake by 58%
• One-Piece Sealed Housing incorporates RAM Active Air Technology
• Pro Guard 7 filter offers maximum filtration protection for your engine, with optional Pro Dry S filter for easier cleaning convenience
• Built-In sight window provides easier inspection of filter without disassembly
• Premium hardware assures a leak free seal and long lasting durability
To order PM me for more questions and for pricing.
Got a '16 3500 6.7L on the way in the next two weeks if shipping keeps on schedule.
I had an aFe Pro-Guard 7 Stage 2 filter in my '07 5.9L Quad Cab. Filter was great. It was this kit - Cold Air Intake System Stage-2 Magnum FORCE Pro-GUARD 7ÂStage-2 Intake System; Dodge Diesel Trucks 03-09 L6-5.9/6.7L (td) 75-11342-1 - aFe Power
Please PM me if yall have any special deals for Cummins Forum members. I would like to get one of the Momentum setups with the Pro-Guard 7.
Also, by any chance is the Pro-Guard 7 air filter from the kit I referenced the same air filter that goes in the new Momentum for the 13-16 6.7L's? If it is, I will be really happy because I will have a spare filter! I still have the housing from that kit too. Did not trade it in with the old truck.:party018:
Dang. Never mind about the question on the '07 kit vs. the 13-16 kit having the same air filter. I checked the referenced Pro-Guard filters on both kits on yall's website and saw they had different part numbers. The pictures look different too. The newer one seems longer.
