I did my stage 1 delete and my 2008 Ram 2500 is not running right. Here's all that was done to my truck before I took it for a test drive on the highway.
1. Unplugged the EGR intake valve.
2. Removed the cross over manifold and installed the round block off plate.
3. Removed the intake valve and installed the block off plate on the intake horn.
4. Unplugged the throttle valve because I read that the default setting for unplugged valve is in the open position. I did not take out the throttle control gear like some people do.
Here's my problem. I drove for about 30 minutes and the red throttle valve light on the dash came on and I lost power (going at about 60 MPH). When I floor the pedal I get power back. It almost feels like the throttle valve closing and choking off the air. Once I stop for awhile and restart the truck the red throttle valve does not come on and at least for awhile the truck runs OK. Has anyone experienced this type of problem? Should I take out the gear in the throttle valve mechanism? I do have the Mini Maxx installed, but I'm not activating the delete programming until I do the DPF delete.
