Problems after turbo install update with codes
Drove the truck today with the extreme tune and still made 36psi. So I decided to check the codes 0234 0602 showed up but the CEL never came on.
I just put on a HTT 62/12 on a 05 predator/puck stack, exhaust, intake. Problem is the turbo spools quick as snot on ice but it never starts to pull hard. Boost hits 36 and just shakes between 34-36. Feels like its fixin to lite around 20psi starts to pull real hard for a split second then just quits. It feels almost like the truck is defueling. Plenty of smoke down low then the turbo cleans it up on the topend egt's are running about 1350-1400 on a pull from 45-90 so I would think with those egt's it wouldn't be cutting fuel would it??
Also while doing the turbo install the batteries went dead on me.
And one other thing about 10000 miles ago the truck turned into a TOTAL turd and I had everything checked and it was all good. F/P, map, FCA, oh and i put new injectors in it to at that time. and nothing took care of the power problem. So i stuck the diablo on and it solved it for some reason ran just like it did with the BDPP.
Need some idea's here.
