21 - 35 of 35 Posts
If you want to do the 63/68 SXE I will be taking mine off soon to put a 64.5/73. It has around 3000 miles currently with limited driving on weekends only. It is a .91 with cerakote on it. I have two compressor covers for it as well, one is a normal 3rd gen elbow the other has V-bands welded on the intake & discharge. I also have the rest of the Evil fab over/under piping that could go with it. Just needs a 2nd gen manifold & standard cover S400.
Discussion Starter #22
Only reason I mentioned it is you stated you were only going to add roughly 30% overs and want to use the truck to tow and just daily it, hard to beat a 351/475 for that.....
That’s very true, really I’m just kind of seeing what’s out there and if somebody's doing what’s in my head lol 351/475 is a dime a dozen, 63/475 non gated not really.
Discussion Starter #23
So I’ve kind of settled on a kit from EVIL FAB, they make a kit that utilizes the 3rd gen style manifold but allows for a t4 non gated manifold charger.
Anyone have any experience with Evil? Their kits seem legit all stainless steel welds look very nice and clean
Riley is good people and makes good quality stuff. No worries there.
I agree, I’ve ran 2 kits from them and there kits are top notch. Excellent customer service
3 footin' through life
I now have a 366/74/1.1 over a 485/96/1.32 and while on the engine dyno I stopped at 1550hp because of the stock 5.9 block and unfortunately on the first pass down the 1/8 it decided to send the cylinder wall on #6 out to lunch. So now a sleeved 6.7 block down to 5.9 factory piston is in the works.
The reason I went to a 1.1 housing on the 66 this time is because I was going to hit it with a .080 jet on the dyno. But I never made it that far lol
Wicked stuff for sure! I'm surprised you are going back with the s300 frame. I wanna get off the s300 frame even its no change in wheel dimensions. Mine never have sealed well to the center section and installation is a PITA compared to the s400.
Yessir! Staying 300 frame. If I went to 6.7 stroke, Id go 400 with a big turbine. Nothing less than 87/1.0
Id probably go 96/1.1 T4 to be honest
But beings I just upped chargers, Im staying 5.9 base
Good to hear. I think I'd like a 72/87/1.0 with 88 :)
The setup on my 07 is from Anarchy they ran good could hit 70+ of boost and never had a problem pulling my camper. I travel all over the US for work and have had it through Colorado, Wyoming West Texas. Truck is currently getting the motor gone through and adding a few parts.
Discussion Starter #30
What was the sizing and fuel setup?
60/68/.91 T4 over a 75/96/1.32 T4 60% injectors and an arson kit on a new injector pump its the 07 in my sig
Discussion Starter #32
What kind of EGTs would you see with the smaller manifold charger? Did you happen to run a secondary boost gauge in between them to see what the smaller one was making?
One boost and one Egt gauge. On a WOT run it would hit 1350-1400 or so. Pulling the camper and driving it i didn't have to worry about it maybe 1100-1200. I'm in the process of having the motor gone through so hopefully in another month or so I can drive it again.
Discussion Starter #34
Well now you’ve thrown a wrench in my thought process lol 60 vs 63.... dang it
I was told that i should be able to make around 750 with the injectors and turbos (turbos may have a bit more) need to add more pump obviously. It pulled the camper pretty good it is a 40 foot bunkhouse. Broke a intercooler t bolt clamp at about 75 lbs of boost it runs good
21 - 35 of 35 Posts
