21 - 40 of 220 Posts
@Got Horsepower
You wouldn't happen to be going to the Corona Recovery Dyno Challenge would you?
Banned
i'm gonna be around 650-660 wheel and 1380trq with specs, care to start a guess thread? lol
Banned
Don't follow! How do you recover from something you don't do???
Uh...that's the name of the dyno challenge at the Flying Wrench in Kingston in a few weeks. I recall you being in the neighborhood.
I was thinking about heading to that same dyno challenge @ Flying Wrench too. Just had them service my transmission through Dynamic and saw the flyer on it. My truck is quite puny on power so it might be interesting to see some bigger numbers from other rigs.
I've been wanting to go to a dyno event for a while to check things out and listen to some diesel sounds. I'm also curious to know what my '15 will do with the modifications it has and want a baseline to go off of when I put in injectors eventually. I'm definitely not going to be breaking any records and hopefully not any parts. They also handled my trans upgrade thru Dynamic and gearing change. I figure if it costs to put the truck on the dyno anyway, might as well enter the contest and maybe take home a sticker or t-shirt.
Reactions: hutchmj
I'll see you there!
2000 Dodge Truck 4x4 Automatic
Discussion Starter · #36 ·
only because the trans and 50psi, cam and meth will help
Boost when it lights is closer to 60 psi???you can have all the boost in the world but if your drive pressure is higher it really does no good. My setup right now boost is 5-10 psi higher than drive pressure. So even though my boost is lower I can actually be making more power than someone making alot more boost with high drive pressure. My setup is extremely effecient!!!
Banned
honest opinion, 60psi from single is too much, meth will be saving grace. Def curious numbers. have my guess in!
Discussion Starter · #38 ·
The ATS 5000 was designed to handle up to 70 psi boost. That's what they advertise. So how is 58 lbs boost to much for a single designed to put out 70 lbs????
Banned
again just an opinion
