1 - 13 of 13 Posts
hey guys, I posted on here about a power steerinp on my grandfathers truck and I can not find the post so I am going to try again. He is thinking about buying a new power steering pump. before he buys one just wanted to see if any one could help me out. The things that this truck is doing just as if you had a trailer on it loaded imprproperly when going through a corner the tail wants to come around very hard to steer we put some new power steering fluid in it and seemed a little better and the next day it was doing the same thing by the way this is a 2000 quad cab auto 3/4 ton.
Go for Broke
sorry guys Im at work and we had a Emergency call
hey guys my grandfather says it wont come to center it seems like to him that it does it at high and low speeds if he tightens the adjustment on the gear box it helps the walkin but it makes it harder to steer seems like you have to gerk it back. just had brand new tires and has been alighned several times he has put a steering stabalizer shock.
Discussion Starter · #5 · (Edited)
had this mixed up a little so this is from his mouth as to what he,s experencing as hes driving thanks guys.
Get a new steering box. I'm betting that's worn out. The pumps on these trucks are pretty dang good.
×2 also check the seal on the power steering box for leaks sounds like your out of fluid. if you can just replace the seal and add more fluid that would be cheaper than replacing the whole box. hope this helps:thumbsup
Discussion Starter · #8 · (Edited)
thanks guys I think he is going to do that just wanted to run it past you because the more apinions you have the better you feel about spending 179.00 just wanted your input and thanks to all who make this forum possible.
Mopar1973Man.Com
As a tire shop but the camber and caster effect the return of the steer wheel. :w:
But yes a power valve isssue in the steering gear box can do the same...
Discussion Starter · #11 ·
he says the casper and camber have been checked tree times and has been aligned
Discussion Starter · #13 ·
no he hasnt but he is going to this week or next and he will see if this will fix it ill let you know.
thanks for the help guys
1 - 13 of 13 Posts
