1 - 3 of 3 Posts
I've developed a small leak but I can't seem to find the source. The fluid is dripping down somewhere in the middle of the front end, it is mostly accumulating on the steering stabilizer, the tie rod in the center of the truck and the front end of the pan. I don't know what is above that location, I thought the power steering pump was on the driver's side but a majority of the fluid is closer to the center. Is there a trans line that goes across there somewhere? I have noticed a few times where it felt like the brake boost wasn't normal and the steering seemed slightly stiffer but then it would go back to normal. Any help before I take it to the stealer so I can steer them (no pun intended) in the right direction?
Well I need to check my sense of smell. The fluid didn't seem right to be ATF. I had a flash of genius and realized that it was actually antifreeze......
Yup I had a water pump that was bad so the dealer fixed it for me today under the engine warranty. All good now......
1 - 3 of 3 Posts
