1 - 3 of 3 Posts
Discussion Starter #1 (Edited by Moderator)
Description: Power Slot Premium Extreme Duty Rotors are exclusively design with the Vac-U-Slot technology to enable better heat and water dissappation. The Vac-U-Slots also act as a visual wear indicator as the slots are machined to the min. thickness.
Keywords: Power Slot extreme duty rotors
The longest lasting pads that go good with these rotors are the Raybestos Semi-Metallic.
Rating10
Prosgreat braking in wet weather
Consnone
Would you recommend?yes
1 - 3 of 3 Posts
