1 - 3 of 3 Posts
With stock 9mm injectors do you get to a point where no matter how far you turn in the power screw you don't get any more fuel?? Does the stock injectors only flow to a certain point.
Discussion Starter · #2 ·
Whoops. Should be in powertrain section.
Not really... You see a benefit with every turn of the screw. The gains might diminish after a point, but that's more due to restrictions of the stock air system and low pressure fuel system than it is injectors.
1 - 3 of 3 Posts
