1 - 13 of 13 Posts
Hi Guys.
Hey, I'm new here, and having a spot of trouble.
I took my rig into have an oil leak fixed, and it was a nasty leak, behind the fuel filter, lines and pump.
Ok, all that had to be removed, and the gasket replaced, then the fuel lines, and stuff replaced/ hooked up.
I picked up the truck and drove it home- It seemed a bit sluggish, but I attributed that to having been driving a sporty little gas powered zippy car around while the truck was in the shop.
I parked the truck in the driveway, and a few hours later went out tried to start it.
Clouds. I mean horrific all your neighbors huge gasp-for-air come out shaking fist clouds of smoke roiled from the truck, and I didn't have any power.
The pedal would go down, the smoke would come out, but the RPMs staggered and fell off with more pedal- Like i was flooding the already flooded engine even more.
Ok, I let the rig come up to about a hundred fifty degrees, and managed to get it out on the road, and once it was motovating it seemed to respond better and stopped blowing a cloud. Still smoking, but at least responding somewhat.
I parked the rig and left it overnight.
Today, on the advice of the mechanic that had been working on the rig, i bled the filter and lines, but that didn't seem to help.
The truck still smokes, and I have no power.
I don't understand how the thing made it home, and then wouldn't run again.
So here is my uneducated theory.
I suspect that the fuel timing is out.
Can anyone else offer another idea why this would start smoking like that ?
Is there a boot, bolt, fuel rail , or god willin' some simple overlooked aspect
of the replacement process that is in someones experience level to tell me to go take a look at? Anybody? hello?
Thanks
Mike
Check fuel pressure first. It should hit 60 psi when the return line is blocked. If you took it to a less than reputible shop there could be something in the lines.
You will find with certain vehicles its better to be a wrench turner then take it to a shop.
Reactions: UMBRA
Thanks.
I will pick up a pressure guage and check that- My tools are all packed from moving across country, but i could stand adding a pressure guage to my toolbox.
The truck is parked at a friends while we wait to move into an old house we got-the upside to all that is i will have a garage when the place is ours, the downside is, the attourneys are taking their sweet time closing on the house, (sniffle) so i don't have my garage to unpack my tools in. ( add rolling drums and sax for drama effect )
But i have my travel set of tools available in the rig packed just in case. I reckon in case is now. Thanks for the input, i best get down to the local parts store, i don't see no mac or snap on trucks rolling by out there.
So you had the pushrod cover (tappet) gasket replaced? That means the injector pump was removed. Sounds to me like the shop did a lousy job. Didn't clean the IP shaft completely before they installed the gear, and now the timing has slipped. Sounds like your "mechanic" needs some training.
Reactions: UMBRA
Yep, that's the gasket- it was a real leaker, and yep, the fuel injector pump was removed and replaced as part of the access. It took the shop three days to get it done.
What I think is that the timing set up was lost in the process, or as You say, slipped and wasn't reset properly.
The leak is better...now I need the rig to run again....
Thanks for the input, I really appreciate it.
I will get the timing reset and see if that is the answer. I believe it will be.
I wish i were rich, LOL. all this would be much easier, or at least more affordable.
Three days:shock: Even a novice could do it in two. (The adhesive for the gasket needs to cure overnight.) I'm betting that you could have bought all the tools and had a stack of money left over with what you paid the "mechanic".
Reactions: UMBRA
I went in to get a state inspection, a twenty nine dollar deal, and walked out about thirteen hundred down and a truck that doesn't go.
It started with the leaks, and just got worse as the days wore on.
I can't wait to get into my house, and my tools unpacked....You're right, it would have made a nice addition to my toolbox contents.
What color is the smoke? If it's black, check for a boost leak i.e.- a boot that didn't get hooked back up or reclamped.
Reactions: UMBRA
The other thing you might have a peek at is the small 6 inch plastic line that goes from the intake to the AFC that sends the boost signal they have a habit of gettting pinched or broken...but i as well and leaning towards the timing deal...
Reactions: UMBRA
Discussion Starter · #10 ·
Southtowns27, the smoke is white and heavy. Thanks .
12valve, i'll take a look at that line this a.m., thanks- I was hoping it would be something simple like that.....so i will be happy to look into it.....but i suspect the timing from all the feedback so far, and what i have read about the timing set being so touchy. There is an excellent reference for the setup here.... i should thank whoever posted that, but will have to go and look again to remind myself who that was....old age, You know, LOL. wait- that's not funny...Thanks Guys
White heavy smoke = slipped timing
Reactions: UMBRA
another vote for slipped timing, sounds like it wasnt timed right to begin with (and either didnt clean the shaft/gear or didnt torque it ) and once you shut it down it spun the gear on the shaft a little more
Reactions: UMBRA
1 - 13 of 13 Posts
