1 - 9 of 9 Posts
ok so what can i expect for power if i get some 75 horse ddp injectors, a built tranny, and say a s300 turbo. along with the pump timing and plate work, it will be a DD and will tow every now and again. thanks
cool, what else could i do for some more power that is cheap?
i dont know something that doesnt lag much and something i can still get good mpg with
a 62/71/14, 90s, 4k, 60lbs and timing would be a sweet setup. Make sure get yourself a decent trans setup and maybe some studs depending on timing and boost level.
ya i want the tranny to hold about 200hp over what i plan to run it at
Definitely a good plan its seems like once I get where I want, couple weeks later I need more.
Discussion Starter #9
so what all do you have done to your truck
1 - 9 of 9 Posts
