do you think that a master cylinder/power booster from an 02 sport would fit my truck?
HERMISTONKILLA · Registered Joined Oct 9, 2007 · 58 Posts Discussion Starter • #1 • May 22, 2008 do you think that a master cylinder/power booster from an 02 sport would fit my truck?
Meierznutz · Registered Joined May 3, 2008 · 205 Posts #2 • May 22, 2008 Diesel to diesel it should be a direct swap. Be sure to take the entire valve body for the ABS if you can so you can do 4 wheel anti lock.
HERMISTONKILLA · Registered Joined Oct 9, 2007 · 58 Posts Discussion Starter • #3 • May 22, 2008 thanks for the help
