1 - 20 of 176 Posts
Figured since everyone is getting into this new tune, to post up what you have and why. what has been working and what has not been working.
yea that would be cool, just trying to start a fresh thread then have the other one cluttered when we were waiting for tntr to come out.
Sw3 tq-2 tm-2 rp-1 wg-off shift defuel- stock rev. limiter - high - for street, still has random rail pop
still looking for a higher tune to dyno/pull with
Sw9 tq-3 tm-4 rp-3 wg-off shift defuel-on rev. limiter- higher, ran on last dyno and didnt do that well, would like to try Sw7 tq-3 tm-4 rp-4
SW 7
Tq 2
Tm 3
Rp 1
Rpm stock
No rail pop, no rail hang, stock cp3
Smooth on the street. Lights up quick and goes like hell when I want it to.
EGT's under 1300* no matter what.
Awesome power super smooth no rail pop and 20mpg at 75mph ! SW 5 default everything, wastegate off, speed limiter 130, rev limiter off! Love it ! so much nicer than the old TNT
Discussion Starter · #9 ·
what timing? ^^^
Sw7
Tm2
Tq4
Rp1
Shift defuel off
Rpm stock
Speed limiter 230
Dr. Performance on performance
No rail pop
Hung for a sec first time floored then didn't happen after that?
Very very low smoke barley any pre boost and virtually none wot
Ran sw9 with all same settings exception of dr. Performance on tow ran good not as strong and very smokey! Pre boost ton of smoke wot thick haze.
^^^^^^^ sorry I for got the and why part! Sw7 instead of sw9 was because on sw7 at a 20mph roll I hit the peddle and the truck broke loose and fishtailed, then doing a u turn floored it and bout drifted around the rear end, it didn't do this on sw9 for me and spinning 37s is fun ha
hey stubs what year is your truck?
Dodge74 what nozzles you running?
sorry to be off topic.
She's a 03 sorry I really need to fill in my sig I'm running 100hp injectors
Reactions: Black03cummins
I am running stock nozzles and those runs were made Smarty only.
All stock?! Smarty alone?! You made 560s damn! I fell I would be luck to touch 500 with my set up!
hey john unless im reading you abv. wrong your torque and timing are switched and you deff lost some power there.... you want your timing on 3 and torque on 4 lol
and yes gordon deff has a strong strong running truck....
I dynoed this tune with whats in my sig, TNT-R SW#7 TM default, RP 2, TQ 3, Speed 250, RPM stock, Shift stock. 532 hp 993 lbtq.
Im dissapointed because I was hoping for 550/1000+ but I guess I was close. I thought the WM would have put me there for sure.
The TNT-R is "ok" for me but I almost think my truck liked the TNT better. My egts are easy 1500 with this tune, Im sure thats kinda to be expected with a race tune so I cant hate it for that...
My truck has never been easy to tune like some others though.
I need to tune it better thats the bottom line. Thinking about buying some dyno time..
SW7
Timming 2
TM 4
everything else default
MP-8 up
I made 444 HP and 892 ft lbs on a dyno around me that evetyone says runs 40-50 HP low. Nice lines on the sheet on HP and Torque, very smooth. The TNTR is so much nicer and smoother than the TNt was. When they got on my truck very little smoke just a small haze was coming out of her. Very very happy with the tune
On a side note does it help at all adjusting the speed??
Not every ones truck responds to timing the same way...believe that.
1 - 20 of 176 Posts
