1 - 3 of 3 Posts
Wondering if anyone has run into this fault? My first go around with it.
There is a 10psi Diffrence between my manual gauge and my Snap-on scanner. The Boost voltage is .08 and the boost is reading 11psi at idle? Thinking the sensor is failed within range? Sensor has good response As far as it graphs good, just 10psi high. This is on a 02 dodge diesel with a Edge EZ chip but it doesn't matter if the chip is plugged in or not its always 10psi high. Truck has low power no other faults. Good LP Pressure and about 25psi boost with the man gauge.
Thanks guys,
bump......
On a 2002, boost voltage should be 1.05 volts, pretty sure thats right its the same as the 2001. 98.5-2000 it should be 0.5 volts.
1 - 3 of 3 Posts
