Plowing with 2007 2500?
700 2
Any recommendations on plow setups? Blade size? Style? V or straight?, I have an 07 Ram 2500 Sport I'm looking to do some light plowing with (driveway, couple residential accounts).
Truck has about 95k miles and I am replacing the governor solenoid/sensor and doing a trans fluid change prior to any plowing. I used to plow commercially but looking for input on what people use for these particular trucks.
Thank you,
Matt
1 - 3 of 3 Posts
Driveways/small residential you'll only need a light duty straight blade. Anything more than that would be overkill.
I run Boss plows and would never run anything else. Absolutely love them and incredibly reliable. My old one was 7 years old with hundreds of hours of hard plowing and still going strong. Only reason I bought a new one was because I wanted the new model.
They make light duty plows and I'd highly recommend checking them out. Awesome products and in the snow business their customer service is second to none.
thank you, i found a newer boss straight blade for $2500 locally...but then found a boss rapid tach 2 power v that was used residentially for $1200...I think I will go with that one.. Thanks for the reply.
1 - 3 of 3 Posts
