Please please help!!
1518 Views 8 Replies 4 Participants Last post by  BlackasCoal
Put the edge on my truck and it cleared all codes. Then this morning started my truck and the parking brake and ABS lights came on. The speedometer doesn't work either. The edge is showing codes u0121 (lost communication with anti-lock brake module) and uo11a (Don't know what it is). I did just rotate my tires yesturday but really dont think thats it but i might be wrong.
1 - 9 of 9 Posts
Samething happened to me with my Bullydog! I called tech support and they talked me through reprogramming my VIN. Fixed everything back to normal!
I recommend you call Edge Tech support (if they have 1) They should be able to help ya out! Good Luck!
Just tied to call and of course there not open. With sucks cause i need it fixed by tuesday afternoon.
Yea I guess they are, I'm working now :banghead: so I forgot it is Sunday. Try first thing in the morning... I was up and running in about 5 minutes time once I reached a tech support guy! Come to think of it mine got screwed up on a Sunday as well!
I doubt it has anything to do with the EDGE, it is a module, not a programmer. It should have nothing to do with speedo/abs. If you want to know for sure, unplug the edge and return it to stock.
my guess is the sensor on your rear differential is the problem. make sure it is plugged in, check the wiring make sure its not cut somewhere. and if it looks fine, take it to the dealer and i bet they will replace it under warranty.
Just took a look at it and looks fine. Is there any other plugs to look at.
I went on to justanswer.com and asked a dodge tech and the problem was with the fuse #30 that i had the edge plugged into. I never got the fuse jumper from the guy i got the edge off of, so i bought one from auto zone. That was the problem. Only thing know is im getting a speedometer performance code. Do they ever stop!
Power Wire Location?
What Plug did you use for the power wire for the EDGE in the fuse box? If you pluged it into the ABS fuse that is probably you're problem. You should use one of the plugs marked spare.
Discussion Starter · #9 ·
I plugged it into the #30 fuse that edge says to use. I had it jerry rigged in there and it worked fine. Its when i used that fuse jumper from auto zone i started having problems. So i jerry rigged it again and i have no problems. It did take 1 or 2 start ups to clear the speedometer cel though.
1 - 9 of 9 Posts
