1 - 15 of 15 Posts
hello, i have a 01 24 valve 4by4 all wheel abs, few days ago my abs and park brake light came on, then the brake pedal would kinda skip until it was too the floor, i tried to bleed the brakes last night but in the front the fluid came out in a trickle, all three abs sensors are reading, does anyone have a idea what could be wrong? is it the master cylinder? :confused013: thanks also it occasionally throws the p0500 and p1693 codes but they never stay on, they disapear after a few starts.
taking a shot in the dark, but my truck did the same thing on the 5 hour journey home with it, ended up being a rotted fuel line ontop of the fuel tank.
thanks, ill puller back in the shop n crawl under agauin
Have you lost brake fluid? If out of fluid is a no brainer.
have not lost any fluid
IF you are getting an ABS and brake light and little fluid to your brakes....sounds like to me that your ABS thinks it has a skidding wheel(s) and is doing it's job...but not at the right time... (triggering the lights cause of input disagreement) I'd bet maybe something like a speed sensor or brake controlling solenoid valve malfunction...or similar....but just my $.02..if it were an aircraft...I'd say brake control valve or wheel speed transducer...
Reactions: 01CTDbraaap
Sounds like a master cylinder.
Ops
had a fe3eling it was the master cylinder, gonna call napa today and see what they have.
thanks
AEdude1971
i went thru all of the sensors and there all reading on the ohm meter, but u are right that does sound like what it is doing, thanks
hopefully the MC works for ya... it'll be an easy fix....good luck... one thing though...resistance is one thing ...but is it the correct input??? i.e. skid=resistance no skid= open?? just a thought?? keep us posted...am interested to see what the outcome is..
Discussion Starter · #10 ·
thank you much, on monday when i gotter n putter back on i'll let you guys know what happens, and as for resistance, do you mean on the sensors? or....? me and electrical do not get along:lol4:
I mean the sensors... I'm an aircraft mechanic by trade...and i specialize in electronics and electrical stuff...just be cause you have a resistance reading doesn't mean you have the correct input to the computer....sometimes a resistance reading can be the wrong input...just depends...a MC isn't a major expense...so see what happens...hopefillyit works for ya..
Discussion Starter · #12 ·
ahhh ic i getcha now, well if the master cylinder is not the issue i will be goin back to the electrical, thanks for the advice sir :headbang:
Discussion Starter · #13 ·
hello to anyone still readin this thread, master cylinder was the problem gotter on today n she stops perfect, although i still have the pesky abs and brake lights still on, anyone has a suggestion would be great. thanks for all the input you folks are the best. :blues:
bleed the brakes again...and again...till the lights go out...you have air trapped in your ABS control proportioning valve...i'd bet...
Discussion Starter · #15 ·
ok will do
thanks :thumbsup:
1 - 15 of 15 Posts
