has anyone ran into an antifreeze leak on the driver side? i have checked the bypass hose near turbo and its fine. i have a 06 2500 hd all i can seem to see is occasionally dripping antifreeze from near the front driver side of engine. head sealing area looks dry. there is a wire bundle that runs between the p/s pump and block and it shows signs of being wet. also the actual drip comes from the plug on crank sensor. pressure tested today and holds pressure well. dosent drip every day...im pulling what little hair i have left out. any suggestions would be appriciated, thank you in advance,jim
06 ram 2500 hd.
bone stock
spoiled baby all its life
06 ram 2500 hd.
bone stock
