Most antifreeze I've ever been around is good for atleast 100k. But you say Mike to dump it every 30k?
Why? I know that's very good maintenance but that's a little extreme. Shoot that's once a year for some people. I know coolant goes bad. But not in 30k!!!
I don't listen to the claims of 100K coolants.
I seen so many good vehicle turned into junk because the owner states, "Oh the coolant is still green it must be still good!" This is so wrong. As coolant ages over time it drifts from pH of 7 to lower (acidic) or higher (basic) and becomes corrosive. By the time you see the rusty color its way too late. The damage is already done. The factory service manual even states the 30k miles (36 month) coolant flushes.
This is why I can proudly display the inside of my radiator and block and its still factory fresh inside. Even crazier yet I don't not use distilled water either its all tap water. No blooms, no lime scale, no problems...
9 years and 185k miles. Perfect cooling system.
arty018:
Here is what old coolant will do to thermostat housing...
