Okay this is my first posting of pics so bare with me but..
I had an S&B box set up and was happy but couldn't leave well enough alone, wanted more whistle so I built a whistler style intake and my own creation to get cooler air to filter.
I used the factory elbow at the turbo minus the plastic vanes, a 5.5 inch metal pipe approx 8.5" long then the factory top elbow (5.5 to 4"OD) then the white piece is a PVC adaptor 4"IO to 4"OD. I had to because I had an S&B KF1035D filter here which had a 5"ID opening. RIght now IAT sensor is just tie strapped on the cooler side, see pic. and filter is bungee corded to keep it stable. The other pics are what I did with my 96 powerstroker before I wised up and got this truck. Using Rigid Shop Vac nozzles and 2" hose installed inlets between chrome bumper and white bumper trim, had to drill small holes and tie strap them in, you have to really get down and look to see how they're secured and your don't hardly even notice them. You can see reflection in chrome bumper of how they're attached at the top. I spaced them to still allow plenty of air flow around them to get to condensor. Tubes are neatly tie strapped together routed behind bumper and up pass side blowing large amounts of cool air into filter area, one towards front and one towards rear. Using a shop vac/blower to test you can really feel the air coming out hoses and thats probably less air than highway speeds would blow in. On the old Ford it dropped the towing temps over 100 degrees on the EGT's. Got a prefilter coming for it and I don't really believe water will travel that far up hose when driving in rain, never had issue with Ford set up. Oh and thru in pic of truck, son's 02 second gen in background.
What do ya'll think?
