1 - 11 of 11 Posts
please post op pics from your bypass installs i ordered mine from chuck yesterday and am looking for some ideas before it gets here.
I dont have pictures, but mine is installed on the passenger side, behind the front bumper in the fenderwell. It tucks up in there and you cant even tell its there.
Did you have to drill and tap into the side of the oil pan for the return?
what is the purpose of this I'm sure I could find out by reading up on it but that takes time and am curious at the moment
The oil cap in the photos I show is the easiest way to return the oil.
Cleaner oil, resulting in longer lasting oil and engine components. The amsoil kit, pictured, filters absolute at 2 microns, most wear causing particles start at 5 microns. Also the bypass helps reduce soot loading, which again leads to longer oil life, and better engine wear, resulting in a lower cost of operating.
Here is an FS2500 setup. It comes under alot of fire from Amsoil guys but it works good for me.
Thanks for the thread Jonathan. Just purchased mine as well and any help in placement install would be appreciated. Thanks for the pics ah and tip for placement cowboy.
search for bypass install and you will see several different locations. then pick the one that suits you the best.
1 - 11 of 11 Posts
