1 - 13 of 13 Posts
So heres what i did today, cept the intake, i did that a few weeks ago. The traction bars i made during the week, we installed them today, and I did the exhaust because the side pipe wouldnt fit anymore.
stock, the day i bought her
stack
traction bars
intake
Cummins Fanatic
That must be the LHAF instead of the BHAF! Nice truck
thanks man
according to k&n that filter flows more than a piece of 4" pipe, which is the size of the inlet of the turbo, so i figured its plenty good :thumbsup
Looks like a first class fabrication job on the bars. I am a bit concerned about thier length but then again, I do not know the thickness of the pipe that you used.
Neat install on the stack too!
theyre 1.5" sched 40 tapered down to fit 1" sched 40. 58" long
Should work just fine. do you have enough adjustment on the Hyme joints in case you want to lift it?
Cummins Fanatic
maybe its just me but i dont understand why you'd lift a 2wd truck
The joints I was referring to are those at each end of the bars. As the truck goes up the geometry changes.
I just checked all my susp. sites and none of them carry a lifts for the 2wd 2nd gens. but i dont think it wouldd be all that difficult to do the hyme joint if necessary
Discussion Starter #13
im not going to lift it, if anything, lower the rear to level it. as far as the joints, i have about 1/2" shorter i can go on each end.
btw if anyone is intrested PM me, if any of you guys want i can make some sets of traction bars or heat shields for cheap.
1 - 13 of 13 Posts
