141 - 152 of 152 Posts
Performing a Drain & Fill on the Aisin AS69RC Transmission
I recently finished the transmission sump filter change and this is what I used to get to the 3 bolts behind the crossmember
1/4” drive with 1/4” flex extension and 10mm socket.
Started the bolts by hand with the flex extension to make sure no cross threading and then put the driver on it and the bolts zipped right in no problem
I was dreading the crossmember removal and came up with this solution
Sent from my iPad using Tapatalk
Guys, i need some help.
I have a 2018 Ram 4500 6.7 cummins cabin chassis with 94k miles and Aisin transmission.
I am an idiot and somehow i miss understood when the transmission needs to be serviced...and i never changed the fluid nor the filter...this mechanic in town who works only on transmission and is very trusted in the trucking community here in west texas...said that if the transmission runs okay i should go ahead and change the fluid and filter and everything should be fine, well nothing is fine.
I got to it tonight, i just finished the job by the book, all the parts were from the dealership, i used only 7 quarts as for right now and i just started up the truck to see what’s up, the transmission makes a “grinding” sound, more like when you are sending something by hand and that sanding sound is continuous ...and also the check engine light Is on, i went through the gears amd that went fine but i didn’t move truck at all and instead i sat down and wrote this thread....
White Lightning
Discussion Starter #143
Did you read this ENTIRE thread though?
Not sure if I would use the power driver, but in looking at the rear bolts when doing the drain and fill at 30K, I thought using a 1/4" socket and ratchet would be the best solution.
I just did my 60k service 2 weeks ago and I needed 9 1/2 quarts to fill it
Power driver isn’t necessary but came in handy for me
There's no room on my 15. My guess would be production tolerances. We're only talking a 1/4 inch. I don't remove the crossmember. I loosen the tranny mount and raise the trans a couple of inches.
That's the conclusion I came to this weekend when I just did my filter change. Even the narrow part of a 1/4" drive extension doesn't fit between my pan and crossmember. I swung down the crossmember as it was only a few extra minutes work but gave great access and I wasn't sure how high I could safely raise the tranny/tcase. Maybe I'll try something different in 6 years when I do it again...
My 3309 came in 5L jugs. I added what looked like almost 8L and I'm right at the top of the Hot zone at operating temp. I also drained it at full operating temp.
Old fluid didn't look bad. Sludge magnets were pretty sludgy but everything else was clean so they're doing their job. I don't tow but I've been running at least a 100hp tune with 37s and 3.42s for the truck's whole life. Somehow the POS Aisin is still alive.
I got a CEL on startup, the CTS couldn't read it but cleared it just fine, as usual. I didn't have my Hypertech nearby (it seems to read everything) but I was expecting to get a low pressure warning so I didn't look into it further. I idled for a minute or so then put it in gear and everything was just great. No giant BANG or BAM or whatever Greg's old beater experienced.
Did this as well this past weekend. My 1/4 drive and extension had no problem fitting in. Just had to go in from the side of the pan and slide over the socket and extension. There is a dimple in the pan for the extension but not enough clearance to go straight at the bolt. I was dreading how to get to the bolts, I even bought those flexible extenders that were recommended earlier in the thread. It was a simple project. I drained at operating temp and added 7 quarts. Will check again next time I'm out but it was fine. Had a little issue when I started it back up. Banged into gear, check engine light for over voltage on my aux switch. Also on the dic said service 4wd and another message I didnt catch in time. Cleared all those with the cts and started it back up and it shifted fine and not more messages or CEL. Can't imagine paying a dealer $600 or more for this easy service.
Next time try sliding the socket and extension in from the side. Cant imagine everyone's trucks are different where some have to drop the cross member and some not. But who knows! I can take a picture if anyone is confused.. thanks everyone else for the pointers in this!
Sent from my SM-G960U using Tapatalk
I bought a used 18 3500. The dealer did have good maintenance records for the most part and the truck has been well maintained. I could not find anything on the 30k trans service. Called dealer and they could not see where it was done. Service writer said that the truck is not due unless used for heavy towing, police,etc. I looked in the book and I believe she was in error. Truck has almost 46k now. Should I just do the drain and fill or wait till 60k and do fluid and filter. What I'm thinking is doing fluid now and both at 60k to get maintenance schedule back on track. Is their any issues with the aisin not getting serviced at every 30k
:agree2:
Service writer was probably thinking about the 68RFE.
"What I'm thinking is doing fluid now and both at 60k to get maintenance schedule back on track."
:agree2:
That's what I would do.
:agree2:
:agree2:
I was able to get to the drain and fill today 46500 miles. Fluid did not look to bad. I put 7.5 of 3309 back into it. Took it for a spin and it is a little smother on shifting. When it hits 60k I will do both.
Reactions: Learjet
