Status
Not open for further replies.
1 - 1 of 1 Posts
hey guys we are going to offer up a few links to some threads and also post some info about various performance parts.
example: is it necessary to replace my stock Lift Pump if i put a power adder of some sort on it. well....yes.
also we would like to link some of the tech write up in our tech sections as a link. this area gets over looked by many members.
any feed back would be great for this thread. you can offer info by pm if you would like to any one of our moderators. we would like to update some of these sections for our 98.5-02 section :thumbsup:
thanks guys :yourock:
24V Retro Fit Parts- anything to deal with better stock parts from other generations
http://www.cumminsforum.com/forum/9...scussion/157104-p-pumped-24v-tech-w-pics.html
http://www.cumminsforum.com/forum/9...cussion/151365-he351-retrofit-second-gen.html
http://www.cumminsforum.com/forum/9...ion/50568-3rd-gen-head-2nd-gen-block-24v.html
The Basics!-general common knowledge
http://www.cumminsforum.com/forum/9...ion/148430-you-want-more-boost-read-here.html
http://www.cumminsforum.com/forum/9...discussion/209413-how-turbocharger-works.html
http://www.cumminsforum.com/forum/9...05321-performance-electronics-hp-ratings.html
http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/205302-smoke-switch-info.html
http://www.cumminsforum.com/forum/9...iscussion/202233-chip-stacking-look-here.html
98.5-02 Tech Articles - Dodge Cummins Diesel Forum
http://www.cumminsforum.com/forum/9...216850-all-injector-info-youll-ever-want.html
http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/312866-diesel-terms.html
Fuel Modifications
http://www.cumminsforum.com/forum/98-5-02-powertrain/247980-son-return-new-guy-info.html
http://www.cumminsforum.com/forum/9...ig-line-kit-fuel-psi.html?highlight=lift+pump
http://www.cumminsforum.com/forum/9...el-pressure-too-much.html?highlight=lift+pump
http://www.cumminsforum.com/forum/9...og-ii-df-165-install.html?highlight=lift+pump
http://www.cumminsforum.com/forum/9...ation-sucess-stories.html?highlight=lift+pump
http://www.cumminsforum.com/forum/98-5-02-powertrain/44567-fass-vs-air-dog.html?highlight=lift+pump
http://www.cumminsforum.com/forum/9...nce/36644-running-fass-stock-fuel-heater.html
http://www.cumminsforum.com/forum/9...nce/12059-afs-walbro-fuel-system-install.html
http://www.cumminsforum.com/forum/9...draw-straw-ii-big-line-fp-relocation-kit.html
http://www.cumminsforum.com/forum/9...ance/8792-vulcan-draw-straw-installation.html
http://www.cumminsforum.com/forum/98-5-02-modifications/3378-what-pusher-pump-why-use-one.html
http://www.cumminsforum.com/forum/98-5-02-modifications/71-upgrade-oem-lift-pump.html
http://www.cumminsforum.com/forum/98-5-02-technical-diagnostics/980-anatomy-lift-pump.html
http://mopar.mopar1973man.com/tips/cummins/2ndgen24v/fuel-pressure/fuel-pressure.htm
http://mopar.mopar1973man.com/tips/cummins/2ndgen24v/lift-pump-diag/lift-pump-daig.htm
Installation Tips and Tricks
http://www.cumminsforum.com/forum/9...cussion/134577-24v-injector-install-tips.html
Power Additions and Combinations
http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/219043-injectors-turbos.html
http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/216421-injector-myth.html
Triple turbos http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/218068-started-thinking.html
1 - 1 of 1 Posts
Status
