1 - 12 of 12 Posts
Ok guys I need some of your performance knowledge. I want to know what the next step for me is to get some more power and I dont know what route to go . Right I am just running The Bully Dog GT, Stage 2 Intake, and 5" Exhaust whats the next steps to make some power
Id start with building a trans or aftermarket clutch depending on what you got. Secondly post your stuff up in your sig to help you out for future questions!
go to your user cp and on the left hand side it will say edit sig....post it up in there. And what kind of clutch is it? what power are you looking to make?
edit...i posted b4 u poseted back so disregaurd tranny upgrades below since u got a clutch
1 Gauges so u no whats going on
2 as said clutch or auto upgrade/whole new trans
3 upgrade fuel filtration
4 then start looking into airdog or fass
5 EFI live if u have an 06+
6 studs
7 big single turbo/twins
8 cp3 upgrade
9 injectors
10 springs
11 rods
and on
and on
and on
and on
get an airdog 150...how much hp are you looking to make?
What kind of filtration upgrade do you recommend
at the very least put a Baldwin PF7977 in the stock canister.
search Cat 2 Micron filter setup or similar
600 hp can be achieved with a large single turbo, smarty, and injectors. probly need a lift pump too but stock cp3 should can handle 600hp
1 - 12 of 12 Posts
