1 - 2 of 2 Posts
Two codes today, Should i get a scanner
Today i got two codes p0483/p0514,and the pass. seat heater switch flashes when put on and flashes on low,anyone know whats up with that. I know codes are batt temp sensor(p0514),i snow plow so it's probably from using plow motor and batt. going from hot to cold alot. And the p0483 is for the clutch fan rotation either to fast or slow,maybe clutch fan is starting to fail or the sensor is going,any help or advice on what to do would be appreciated.Also could you use a scanner to erase codes or will they erase themselves over a certain amount of ignition cycles providing the sensors dont throw another code before that time.:confused013:
hey did you ever figure it out? I replaced my seat cushion and now the seat heater switch blinks like yours. I kinda think i broke sometign in the heating element.
1 - 2 of 2 Posts
