I'm ready to start upgrading my truck more. I'm looking at a Quadzilla Adrenaline, 90hp DDP's, and a 62\71\14 turbo, and a SBC DD 3850.
I tow frequently, and I'm wanting to know if my EGT's will get hot with this setup. The trailer normally weighs about 18-20k
Thanks
na , you should be fine, I'd lose the bhaf and go with something like an icebox and 4" all the way back. I towed 3 loads from Missouri to Texas grossing 35-42k with 150's and a ps 62/14 and didn't have to worry too much. You'll lose that extra mid-range gear with the 5spd but I think you'll be o.k.
I wanna go fast...
Have you fixed 5th yet? the extra power tends to cause a problem with this. My .02, should stay cool, but you need to monitor your fuel psi. Or add an Airdog or FASS.
Still on the stock trans, but the previous owner might have fixed fifth. How hard & costly is the fix?
Should be a good setup. If you don't already, make sure you get a lift pump and guages.
