1 - 3 of 3 Posts
2008 F350 CCLB SRW 02 24v 5r110
I bought a complete 95 12v to swap the p pump to my 24v. How much of the stuff from the 12v will work with my 24v? Am I going to be able to use all the timing stuff (covers and gears etc.). From my research I know I will need oil feed with an orifice, along with a bracket to support the weight of the pump. My 24v currently has a VE pump on it, is any of the VE stuff compatible with the p pump? Can anyone help me with a parts list? I'm okay with buying a conversion kit but is that necessary with me having the complete 12v? Side note: I don't want/need a mechanical lift pump.
· On call 24/7
I don’t remember having to buy an extra bracket, seems I used one from the 12v. I think I got injector lines from Scheids. Are the housings different from ve to p7100? Would be great if you didn’t have to pull the front covers!
The front case is specific to which pump your using . Scheid makes a very nice set of injector lines . Throttle linkage to work with your Ford . Crazy Carl's has the oil line for the pump .
1 - 3 of 3 Posts
