This will be added to my modifications in my sig.
Air dog 150 or fass 150
Billet TC
Arson 2 kit
35% extrude honed nozzles
SB 66mm
That you think? Will it work?
Sounds like a good setup. What is the size of the turbo other than a 66? 66/71/14 I would assume.
www.ATSdiesel.com
have you thought about using an Aurora over the SB? and make sure you check out our 5 star TC ... i can show you many reasons why its the best out there... as for AD or FASS, I prefer FASS but its all up to personal preference as they are very similar... and then as for your arson kit, our dual kit will keep flow and pressure much higher and more reliably due to its design... let me know if you need any assitance
Guys could I run the smarty tnt program with just the arson 2 kit or would I have to get a higher flow cp3?
Thanks corey
You could get away with running the tnt on the "lower" tunes such as 1-3 with a dragonslayer but...you are still gonna drain the rail like crazy. To effectivly run the tnt you REALLY need dual cp3's.
