A buddy is parting out his rust bucket 2nd gen.
What should I get from him to liven up my first gen?
Turbo?
Exhaust manifold?
Inter cooler?
Exhaust?
What year is your 1st gen? What year is his 2nd gen?
1st gen 93
2nd gen 94
IF you can get them cheap enough, I would go for the IC, Turbo, Exhaust and Intake. IIRC, same engine as the 93, so grad the IP and injectors as well.
Thank you
Will grab those and probably the engine just for spares.
Ducati M.
94 is a p pump engine, and the turbo is a wh1c. Same turbine housing as the later hx35, and similar compressor to the hx, but the cartridge is the same as the stock h1c. If the 2nd gen was an auto it'll have a 160hp pump, or a 175hp pump if it was a stick. the stock p pump injectors are smaller than stock ic ve injectors, but same spray angle.
Thank you for the input.
