I put new rotors on the back of my truck and the parking brake pretty loose with the new rotors. The pads on my parking brake didn't look to bad. I adjusted the little star wheel to where it was tight and the pedal is tight but my brake doesn't hold very well. Any ideas?
Perhaps the new rotors had a little grease on them to protect from corrosion during shipping? If you didn't clean them I would take the rotors off and clean the little shoes AND the drum part of the disc. Wish I had disc. :(
Lucky A$$ with discs! Did you tighten the cable that run from the cab back to the E brake? I adjusted mine once and it worked wonders.
The E brake is tight when you push it to the floor. I didn't clean the rotors off i will have to try that thanks.
Clean your main pads too if you didn't clean the rotor at all! :) Almost all drum/disc manufacturers send their stuff out with oil or cosmoline or something to prevent corrosion. Tacky greasy stuff. It gets in the vanes in the rotors and makes weird smoke (no big deal) that can really freak you out when you warm them up the first time!:eek:hno:
