P7100 ok with stock 24v lift pump??
1092 Views 2 Replies 3 Participants Last post by  iniviate
I know i should have bought the fass first but, i had to buy the ppump kit before anyone else did. And i dont have anymore money to spend on a better lift pump yet. Just wondering if the truck will be ok as a daily driver for a week or two without hurting anything with that stock lift pump on the block.
1 - 3 of 3 Posts
I'm not quite sure it would even run? the p7100 requires more pressure than the VP did and the stock LP was failure prone for the lower pressure.
You would be risking damage to the p7100 if it runs at all.
i bought a 12 valve truck that ran and drove on 3 to 0psi. it was very slow, but otherwise ran fine.
i changed the overflow valve and pressure went back to normal, so i'd say it had been like that for years.
it'll be fine. i did mine the same way.
1 - 3 of 3 Posts
