P1698 New alternator not charging
11445 Views 14 Replies 6 Participants Last post by  labans
This all started about a month ago... My truck is not a daily driver, it hadn't been started in a couple weeks and I knew the batteries were getting weak. I started it one morning and when I turned the headlights on while it was warming up the radio turned off. I also noticed the voltmeter running lower than normal. Thinking this was odd I decided to drive it to NAPA and replace the batteries (7years old) At this point everything seemed to be back to normal (as far as elect issues such as radio shutting off) After the truck idled for a few minutes I noticed the voltmeter was running down around 11v and after idling longer the voltmeter dropped to the bottom of the gauge. At that point I checked the alternator and determined it needed to be replaced (it was the original) Fast forward to after the new alternator is installed and the charging issue still exists. Since then Ive removed the new alternator and had it bench tested (it passed) and reinstalled it. I have also visually inspected all battery terminal ends, and ground connections I can think of, I also checked all fuses with my multi-tester. I also had NAPA bench test my old alternator when I returned for core charge and it failed the bench test. Any ideas on where to look next? I would really like to fix this myself without having to pay a mechanic but I'm not very good with elect issues.
1 - 15 of 15 Posts
I expect you have one of two issues. Either the replacement alt was bad in the box or the PCM is not causing it to charge. I got a brand new(not rebuilt) Napa alt that was bad in the box a few months ago. I got lucky and found it before installation by pretesting before carrying it out of the store. So take it back and bench test it.
:agree2:Absolutely... ALWAYS test the alternator BEFORE leaving the store new or rebuilt. I've got one member that bought 4 brand NEW Bosch alternators and all 4 where failed in the box. So NEW doesn't mean better or guarantee you've got a good alternator.
My factory alternator died from a failed bearing. So I bought a reman'ed NAPA and bench tested before leaving the store. No problems. Still re-test here at home every oil change just takes a few minutes. :thumbsup:
This all started about a month ago... Fast forward to after the new alternator is installed and the charging issue still exists. Since then Ive removed the new alternator and had it bench tested (it passed) and reinstalled it. I have also visually inspected all battery terminal ends,
Thanks for the ideas. I'm looking into PCM for now.
First somebody, maybe mopar1973man should be able to tell you how to test the pcm. There is also a cheap external voltage regulator you can install and have no negative repercussions, instead of replacing the whole PCM. Also check the two little wires on back of the alt. One should be from the pcm and the other should always be hot with the key on to energize the fields.
Actually the only way to bench test a PCM is at a dealer with DRBIII tool.
Blue should have 12V with the key on. The green wire is a variable ground. All master grounds for the PCM, ECM and VP44 are on a single lead at the passenger side battery.
As for external regulators there is reason why those were ditched years ago. It's because it will cause shorten battery life because of improper charging voltages. External regulators only use the under hood temperatures for voltage regulation so on a cold day the voltage is super high and on a hot day the voltage is super low. It have zero regards for actual battery temperature so more time out of ten the batteries take on damage from under charging, overcharging or boiling out the water even on sealed batteries. The new PCM has a temp sensor under the driver side battery and monitors battery temperature as the battery charges so the battery temperature rises. So the regulator tappers back the voltage.
I only suggest the external regulator as a stop gap to allow the owner to continue driving the truck till he can get a replacement PCM. I do not suggest the external as a permanent fix because its not.
Let's say every vehicle I own I will get 10 years plus from batteries. My entire house is powered by batteries, solar and hydro generator too. So I understand how to properly maintain and service batteries for the long haul. This is only $4,800 to replace... I'm sure going to get 10-15 YEARS before replacement.
Impressive off grid set up, you should be proud, not my skill set ,but nice
Simple point I'm making is proper charging process is key to life span of the batteries. Also there is a reason Dodge dumped the old school external regulator for the PCM regulator. All comes back to life span of the battery and charging performance. I'm not going to say the old regulator doesn't work which it does. It's just that PCM performance is bar none the best voltage regulator you can have. Battery life span and starting performance is way better than the old school old school you can be promised short battery life span and more need to filling with distilled water.
Mike, couple of questions. Are y9u saying here is no way to test the PCM regulating ground on the truck, rather than bench test? Don't the external regulators operate off of draw rather than temp?
On you house system, if you water and solar quit totally for a while, how long would your batteries last with significant damage? How many KWH? What style and size or capacity are your batteries? What are you using for a generator/alternator on your water system? PM if you like.
PCM can be tested by a DRBII tool at the dealer. That is the only thing I know that can test for proper operation of the PCM. There is no end user testing we can do really other than it charging or not.
No. External regulators work off of engine bay temperature. As the external regulator senses heat from the engine it tapers back the charging rate. Being there is only 2 wires to the regulator +12V (switch) on the blue wire which provides power to the regulator and the field of the alternator. The green wire is the field ground that is variable that the regulator produces. Regulator ground is the case itself. So there is absolutely no way for it to work from load. The only factor it has is temperature.
So an example. If you happen to have a bad thermostat and the truck never warmed up properly in the winter and the under hood temperature remained sub-zero your batteries would be boiling (gassing) as you drove down the road because the regulator would be over charging well after the batteries have warmed up and no longer required the high voltage.
Wouldn't an ohm meter to the pcm to alt ground wire show zero if not working and at least something if sending signal to charge?
something else to look at is if the grid relay is stuck on, that will show as a voltage drop and after a short span, the alternator cannot keep up with the load...I'd suspect this as he said the alt passed the test, and sounded like the volt gauge was dropping fast (which will take a longer period of time if alt not charging and just running electrical systems
Simple test just unhook the the two grid heater leads at the driver side battery.
Thanks for all the help so far!
I'll look into these ideas. I dont have a lot of daylight to work on this right now but I'm gonna go try a few things right now...
I had a similar problem on my 2000 dually and after checking all the wiring and finding nothing amiss I opened the fuse box to find the 140 amp fuse blown!! OMG! Autozone does not carry this one but OReillys does and for $4 I was back in business with no further problems. I think when I took one of the batteries out to clean it's tray I must have bumped a hot lead to ground and busted the fuse.
Good Luck; I hope yours is as simple as mine.
1 - 15 of 15 Posts
