1 - 2 of 2 Posts
I have 2013 2500 Cummins. I recently put a Rev Max valve body and solenoid pack from revmax and deep pan. I re- tune on the truck. I keep getting check engine light with codes p0934 and p0935. Truck doesn’t go into limp mode and drives perfect. I also had replaced the pressure sensor switch on the tranny. The check engine light only comes on at cold starts. Anyone have any suggestions on this problem.
I’m experiencing the same thing, mine does it once I start getting the engine load and throttle position up. I’m thinking because I ran 225psi maybe a damaged the pr valve in pump. I got a next gen valve body and new solenoid, and line pressure sensor. Don’t know what else it could be
1 - 2 of 2 Posts
