I am getting code PO628 truck will not start I have checked relays Is the any other fuses that I have not seen? Thanks
Can U Hear Lift Pump Run?? Bump Yer Key And Listen It Should Run For 30-40 Sec
It's the transfer pump
I had the same code pop. Just last Friday the truck died about a mile from the house. It took me 30 mins. to get running long enough to get home. I had to get the upgrade kit from the dodge dealer & install it. The hardest part was getting the fuel tank back into the truck(it still had about 22 gals. of fuel in it). The instrutions were very clear. A extra pair of hands would be helpful when doing the install. The price at the dealer was $341.00 across the counter.
· Cummins Enthusiast
Had the same problem and unfortunately got the intank replacement on later for me to have to destroy for my airdog. Just get an airdog!
Sent from my Autoguide iPhone app "what's your sig?"
Lift pump, I had the same code, I'm lucky my pump is on the back of the filter housing. I got a $159 genos pump, installed and runs better than it has in a long time. Good luck with yours.
