The p2509 code is almost always caused by a low battery, or starting in extreme cold weather without being plugged in overnight. It may take a good charge or drive cycle for your voltage to return to normal range and will then let you clear the light. The p0489 code will only show up when another code appears at the same time. If you download our latest update from our website this code will be fixed, never to return. The p0513 code can be set when changing tunes, it is a skim key code and should be able to be cleared right away. This also is fixed with the update. Email or call us if you still are having problems after you have done the XRT update, we would be glad to help.
Casey
Casey
