got rid of previous codes, now this one , and see dealer now, at an idle turning on the ex brake the tone will change, truck is still defueled or something, got it fast enough to know the ex brake works, just no power and limited rpms. I tried the b b t t t, tried b b t t . It won't leave, can the ccv filter cause the problem?
Trying to learn
sorry I didn't read the fine print I guess.
Looked at the truck today seeing that my actuator is not plugged in. I went and looked at my brothers truck and his actuator is plugged in. So I must have lost mine. I didn't do the work so I don't know when it was lost.
Leave it unplugged. Your truck will thank you for it.
The truck is deleted . The MAP sensor was fairly dirty. Key on off on off on shows p0489, but smarty does not read it, all lights are out, Thanks to all that replied, it sucks when somethig so simple can be so hard.
I borrowed a actuator and plugged it in, took a while but all is good.
