is this normal after injector install. installed 90hp from gus at farmboys.
rsnall · Registered Joined Sep 23, 2007 · 250 Posts Discussion Starter • #1 • Apr 21, 2008 is this normal after injector install. installed 90hp from gus at farmboys.
Justice4all · I bleed diesel Joined Aug 9, 2006 · 1,342 Posts #2 • Apr 21, 2008 (Edited) rsnall said: is this normal after injector install. installed 90hp from gus at farmboys. Click to expand... Just read your other thread. How long had the injectors been in before you got the code?
D dwaynec · Registered Joined Nov 8, 2007 · 86 Posts #3 • Apr 21, 2008 mp-8, predator, 90hp sticks... get a rail pressure gauge, but it looks like you will be needing a cp3 upgrade...
