1 - 1 of 1 Posts
I have an 03 in the shop, will not shift into overdrive. It has the code p0123 which is tps voltage high. I can watch the tps sweep on the scanner and it is working correctly. The code will not clear. Obviously the engine sees the correct tps as the throttle works fine. Any thoughts on this issue. Thanks Dave E
1 - 1 of 1 Posts
