P0073 Ambient Temperature Sensor High
P0107 Manifold Absolute Pressure Sensor Low
so how is this fixed just got it today...?i found the problem it was the intake charge temp sensor... the one that goes on the intake... it is a map sensor reads temp and pressure.. so i guess we have pre and post turbo maps sensors... talk to a tech and they do talk to each other and decided some fuel and timing... thanks guys....
Sorry to bring back old thread but getting the p0107 code recently on my truck as well .... at about 70 mph it will do a slight hesitate for split second then its fine . Anyone able to post a pic of the sensor they replaced ? What was the cost ? Being forloughed from my job id like to try and fix it myself to save few bucksi found the problem it was the intake charge temp sensor... the one that goes on the intake... it is a map sensor reads temp and pressure.. so i guess we have pre and post turbo maps sensors... talk to a tech and they do talk to each other and decided some fuel and timing... thanks guys....
The sensor is in the intake on the head. Find a contact cleaner that doesn't affect plastics. Remove the sensor and clean it.Sorry to bring back old thread but getting the p0107 code recently on my truck as well .... at about 70 mph it will do a slight hesitate for split second then its fine . Anyone able to post a pic of the sensor they replaced ? What was the cost ? Being forloughed from my job id like to try and fix it myself to save few bucks
Which general area will i look ? Just wanna make sure i find exactly it . IF anyone could post a pic it would be greatly apprecaitedThe sensor is in the intake on the head. Find a contact cleaner that doesn't affect plastics. Remove the sensor and clean it.
I am having all the same issues, what fixed itDoes when I get P0107. Been fighting this for about 2 months now. An ideas truck goes in limp mode. No power over 2k and the rail pressure is jumpy bounce from 7k to 20k with just a tap on the pedal.
