1 - 20 of 43 Posts
Hello all,
I own a 2014 Ram 2500 with 44k miles on it currently. The check engine light just came on. I connected my OBD scanner to it and the codes I’m receiving are P003A and P00AF. After looking into the codes I’ve read that it could be the actuator or the turbo itself. Has anyone here experienced the same codes? Is this normal for a truck with low mileage? Not sure what to do. I’m dumb as a bag of hammers when it comes to Diesel engines. Any help or advice would be greatly appreciated.
If you search here, you will find LOTS of info on this.
I take it you have no warranty on this truck?
Were it me, I would clear the codes and see if they come back, if so then you can try replacing the actuator or just do the whole turbo. Find a good independent shop to handle the repair for you.
No Sir. No warranty. I tried clearing the codes and drove the truck about 4 miles and they appeared again. I found an actuator at Genos garage for about $895 and it says you don’t need to do the computer calibration with it.
Have a friend that went with the City Diesel actuator from Geno's and it worked great. Saved him thousands over what the dealer wanted. It was plug and play and it is a more robust design then the stock unit. "if" mine ever goes out that's what I am putting in.
Reactions: Mpsylvia41
I’m thinking of getting the one from Genos. Does anyone know how difficult it is to change the actuator out or should I have a shop do it? I’m pretty good with a wrench.
Replacing just the actuator is fine, but you have to make sure that the VGT vanes in the turbo are working perfectly free, if not then the new actuator will go south quickly. They get a carbon buildup in the mechanism that makes them not move freely throughout their travel range.
My friend is no mechanic by any means and he was able to do it.
Discussion Starter #8
Got it. If I have to replace the turbo all together do you recommend going OEM or aftermarket?
I think you can get a new fleece cheatah for quite a bit less than oem, but probably a turbo rebuilder could just rebuild yours cheapest of all.
Discussion Starter #10
Ok. Thanks for all your feed back. I will keep this post updated with the actuator install. Hopefully it will help someone else who might run in to the same problem.
I used an actuator from vehiclemodule.com it was 580 bucks pre calibrated with an optional 6 year warranty for 60 bucks no core charge they just won’t activate warranty until you send in a core. Actuator install was super simple just take the wheel liner out of the passenger side and drain your radiator first. 1 electrical connector and 4 bolts and you’re back in buisiness. Whole thing took less than an hour including the radiator drain.
Discussion Starter #12
Awesome Brother. Thank you. I will definitely look into that acutuator. I will post an update with pictures of the new one and the install. I’m praying that this will fix the problem.
A couple tips for future turbo health on your truck, use the exhaust brake anytime you can, and give the turbo a little cool down time before shutting the truck down, especially after highway runs and towing/hauling.
Discussion Starter #15
I’ve had this truck since 2015 and I don’t think I’ve ever used the exhaust brake. Maybe that’s why it’s giving me a problem.
Using the exhaust brake makes the VGT vanes travel through their full range, this helps to keep the carbon buildup down.
The exhaust brake will also greatly extend the life of the brake pads.
I run mine in the full on position all the time, except in snow/ice conditions.
And, I give it cool down time before every shutdown.
Turbo and actuator on my truck is original, 529K miles.
Discussion Starter #17
Wow! I better make sure the exhaust brake still works.
Yeah I run my exhaust break on auto and use tow haul mode exclusively unless I’m in the mountains or pulling a trailer then I use it on full
Didn’t know how important it was to run the exhaust break.
Even more important to use the exhaust BRAKE... 😝
1 - 20 of 43 Posts
