Was driving the truck hole from Maine an the truck started shaking for a few secs an made a noise an lost power, black maxx says crankshaft/camshaft mis Aline something. Tryed turning the truck over after I checked everything, turns over fine but no start? Did something on the shaft brake?
From the service module:
P-0016-Crankshaft/Camshaft Timing Misalignment - Bank1, Sensor 1
Causes:
ERRATIC CAM POSITION SENSOR SIGNAL
CAMSHAFT POSITION SENSOR TONE WHEEUPULSE RING ERRATIC
CRANKSHAFT POSITION SENSOR SIGNAL
CRANKSHAFT POSITION SENSOR TONE WHEEUPULSE RING TIMING SPROCKET ALIGNMENT
Most likely just a bad sensor.
Pm me your email addy if you want the whole diagnostic write up. I would post it but I'm limited on my tablet.
I'm not positive but I think this is the code CRANKSHAFT POSITION SENSOR TONE WHEEUPULSE RING TIMING SPROCKET ALIGNMENT, I will have to look at it again tomorrow
Could something have went in the bottom end?
