Depends on if you do it your self.
If you have someone doit for you i think it will cost about $4000. With $2000 or more in parts.
You need a new front cover and gear train, cam depending if you want to use a mechanical lift pump. oil feed line to injection pump, injector lines, cam postioning sensor. etc. haisleymachine.com has all the parts you need.
