First of all I picked this truck up as a project. Previous owner lost interest. Here’s what it has done to date.
2001 HO engine completely resealed.
crazy Carl’s p pump swap kit
Industrial injection 215 pump(new)
Hamilton 100# valve springs
Stock cam
Hx35/40 over s400 compounds with crazy Carl’s compound kit.
glacier diesel belt driven lift pump
PDD 7x0.010 injectors. (150 hp honed from industrial injection)
Ok. So previous owner assembled all of this and never got it to run correctly. I bought it cheap and am kind of banging my head on the wall. When I brought it home it would barely crank and run. Very Smokey, white grey smoke. Lots of it. I figured it was a timing issue. Set AFC back to essentially stock. It was maxed out. Set pump to TDC, no timing pin in the CC timing case so I did a quick valve overlap time on it. Marked the harmonic balancer, can’t get it to crank. Fires immediately with a shot of juice. Ok, must need a tad more timing. Advanced timing four degrees, still nothing. No crank.
I was planning to pull the pump anyway as it had an oil leak on the lifter galley that I want to fix. Is there something else I should be looking at? More timing? And yes, the FSS is working properly. Help a guy out here.
Stock cam
