1 - 3 of 3 Posts
Is there a write up on taking a P pump off a 97. I need to get it off tonight so I can drop it off tomorrow morning to be looked at and I cant have my truck down since its my only set of wheels
Thanks everyone.
05 CUMMINS
Type question in search, see what comes up.
you just need to set the truck to TDC, then remove the injector lines, fuel feed & return and drive gear, unbolt the APPS/linkage and the AFC boost signal line, and unbolt the pump. 4 nuts @ the front and 2 bolts down in the middle.
1 - 3 of 3 Posts
