its no to diffcult, ur not goin to gain much unless u port and polish the the head. 12v can flow just as good as a 24v.
You're talking about air flow through the head, he's talking about converting to a p7100 injection pump.its no to diffcult, ur not goin to gain much unless u port and polish the the head. 12v can flow just as good as a 24v.
i was tought that a ported 12v head flows as much as a stock 24v heada 12v is a stronger block and you can get just as much flow with 12v as a 2
:ditto: :ditto:the blocks are all essentially the same, in design and strength, with the obvious exception of the '53' blocks. same engine, more valves, basically (little more complex than that)
The 24v with a p-pump will make a bit more power than a regular 12v p-pump because of the obvious flow increase of the 24v head.
A ported 12v head is supposed to flow similar to a STOCK 24v head.i was tought that a ported 12v head flows as much as a stock 24v head
ya thats what i was trying to get at. ha. when i get out of school im going to take my truck i have now and build a puller..so prob 13mm p-pump. port and polish custom sticks and a big ol turbo.A ported 12v head is supposed to flow similar to a STOCK 24v head.
stock for stock the 24v flows more, ported vs ported the 24v flows more...
