hello, what is the pump lift setting for 18* timming on the injector pump on a p7100?
M mike uz · Registered Joined Feb 9, 2008 · 273 Posts Discussion Starter • #1 • May 16, 2008 hello, what is the pump lift setting for 18* timming on the injector pump on a p7100?
D Dual K20s · Tech Specialist Joined May 16, 2007 · 2,034 Posts #2 • May 16, 2008 What CPL #? If its the one in your signature 18° = 5.3mm
D dodge359 · Registered Joined May 13, 2007 · 205 Posts #3 • May 16, 2008 Dual K20s, How about 17* on a CPL 2175? TIA
D Dual K20s · Tech Specialist Joined May 16, 2007 · 2,034 Posts #4 • May 16, 2008 about 5.7 maybe a hair more but its unlikely a few tenths will matter Heres an extended table I made. Basically .5° = .1mm This doesn't take into account cam ramp rates and such but its more accurate than most can get it
M mike uz · Registered Joined Feb 9, 2008 · 273 Posts Discussion Starter • #5 • May 16, 2008 thanks, duel K20s mike
