Back when i had my powerstroke and i was always on thedieselgarage.com there was a guy that had 13 or 15 gaugesI want to see someone put 4 gauges down the A-pillar, 4 across the dash, 4 up under the trip computer, and 2 over the steering wheel. Then you'd be truckin. :thumbsup:
Aside from the wedging I did that 3 times... Left the gauges out for 24 hours to recude weight and still next hot sunny day it would droop!go out and but some good 3M stuff. rubb alcohol ove the plastic and the window. than take a mini toarch to the window and see all the water vapor come out of it. stick the pod on and wedge it up for 24 hours and il will tell u after that it will never fall off ur window.
Do you have more info, pics, or a link to the sheetmetal bracket for overhead gauge mount?I like my 4 gauge. I fabbed up a sheetmetal bracket to hold the gauge pod in place from instructions on this forum. Basically you pull the overhead console a part and mount your fabricated bracket to that. I just put some doublesided tape on the windshield to avoid rattles (didn't pull the adhesive strip to the windshield). Double sided tape in Utah doesn't work out to well in most cases (and with how often we go through glass out here, it's not exactly windshield friendly) due to heat/cold extremes.
My Autometer pyro and boost gauge came with enough wire, tube (just) to not need an extension.
http://www.cumminsforum.com/forum/3...ep-overhead-gauge-pod-stuck-windshield-2.htmlDo you have more info, pics, or a link to the sheetmetal bracket for overhead gauge mount?
