I have a 1992 12 valve Automatic swapped into a 70 Crew cab. Control module deleted. I need to wire up the overdrive. Does anyone know how, wire colors from trans? all the info I can retrieve the better
Yet another method that I've read about is using a potentiometer. Just search "tps delete potentiometer" for links and videos to explain how to set it up.
So it ended up being a blue power wire and an orange with green stripe wire as ground. Both wires come right out of the drivers side of the Transmission. I ran an keyed acc.+ wire to the blue wire and the orange wire to a switch on the dash to ground. Works good. Thanks
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
